External vac and solution hookups
Noidios
Russ Zinck
I've seen plenty of pics on here with external exhaust, vacuum, and solution hookups. I'd really like to get one of these setups, but I can't seem to find anyone selling them. Any tips?
C
Chads
I'd say go to the hardware stores and start fabricating its mostly just a little plumbing just take your time and lay it all out and make your adjustments and remember measure twice cut once. You can do it !!!!!! :D
the vacuum is easy enough to connect externally but my truck has an internal solution line hookup but it feeds out of the truck so that I can close the box. I don't like leaving the box open when the tm is running. There are too many idiots outthere that will want to put their hand somewhere it shouldn't be
SRI Cleaning
Anthony Firmani
I d be afraid of the solution line freezing up at night. Or on a long cold drive.
