Effing Evo wand..
Meter Maid
The Undetective
Dayton,Ohio
I’ve use the Bentley (I know, shut up) for the couple years I’ve owned my TM, up until I started using the 1.5” Evolution a couple months ago.
My customer base hasn’t changed, my way of following up with customers hasn’t changed. My machine hasn’t changed.
The only thing that’s changed is my wand.
All the sudden, I’m getting callbacks for spots wicking back. I can trace the callbacks to when I started using the Evo.
Does the Evo suck or is it because I went from a 2” wand to a 1.5” wand? Or, so I suck? I do plenty of dry passes and I don’t overwet the spots.
Hopefully my new Mach 12 2” will be here soon and then I’ll know.
San Francisco, CA.
I chopped up my PIA Bentleys.
The 2 inch EVO is better than the 1.50.
on a 1.50 EVO I would not go higher than 4 flow.
My 2 inch x 14 inch dev pro wand is my wand of choice.
Reactions: Meter Maid
sassyotto
Wisconsin
Paul
the chatter causes a loss in airflow and the vacuum needs time to recover, so they say.
The Sapphire 12 is better than the Mach12, smaller vacuum manifold, far better jet placement.
would you recommend the Neptune hose or Stainless Steel tubing for the SS 12 inch wand?
The EVO 's head is just too light to make continuous contact.
Try adding some weight to the head in some way.
My 28 year old 16 inch castex with a glide is perfect
