Dream Truck Mount
Art Kelley
Clawson,mi
What would you want if you could design and build from scratch. For me reliability is foremost so I would want a direct drive with a van that wouldn't break down for hundreds of thousands of miles. At least a decade of hard use.I'm thinking a Lexus full sized van about the size of my Chevy Express so it just barely fits in my garage. Nice and luxurious with leather seats, sun roof, great audio. Too bad the Japs don't make a full sized van.
The machine would have dual #6 blowers with enough silencers to make them as quiet as the motor idiling. Two waste tanks so you'd have true dual wand capability. Heat exchangers hooked to the blowers, radiator and van engine exaust. 300 degree heat.
Silent and deadly.
Chris A
OH
a HM cds that would hook up to a diesel van, and a 210 waste tank option (I know sounds a lot like a butler...)
FB7777
oh boy another truckmount porn thread :mrgreen:
some of you freaks need to get laid on a regular basis :shock:
buy a fleet of Butlers, and go live your life
Art Kelley
Clawson,mi
I don't want a crap machine in a crap van.
FB7777
thats why I said Butler :mrgreen:
Hey I the dream machines for my operation... you're the one searching !gotcha!
I have my dream tm, but I don't have my dream truck.
Give me a 6.0L extended gmc savanna, low miles, for 15k or less and I will be living my dream.
ronbeatty
Altoona,PA
Ron Beatty
I just spent the last two months designing it, from the 18,000 lb chassis, to the heavy duty box and equipment placement to weight distribution, only to be CRAPPED ON. NEVER believe something that sounds to good to be true, it rarely works out !!!!!!!!
Jesse
-Diesel e-450 dually, extended van with roll up rear door Not a (boxtruck)
-Pto driven 59/68 blower water injected pulling 19-20hg
-1 Emperor HTF2221S 10.2gpm 3000psi pump + 1 emperor HTX1813S 3.5gpm 2000psi pump. Both on their own clutch.
4-stainless steel coolant exchangers from Johns Customs
90 gallon usable waste tank. Apo running to another 300 gallon waste tank which will overflow to a live garden hose reel.
430 gallon fresh water tank
As big of a hose reel as will fit + a steel frame on the nose of the van that will hold another vac hose reel made to be taken off and on when needed.
TimP
I want a van I can stand up like a dodge sprinter. I don't want a cab over truck. I don't need a huge fresh water tank. 100-150 gallons is plenty and the sprinter can carry it. I want a dual wand machine that can keep up with two high flow wands/rotary extractors and keep 230 atm. I want it to be able to pressure wash too. Hose reels that holds 400' of hose.
TimP
kolfer1 said:
The best one is the one that starts every time you turn the switch on.
All the rest is fluff!
That is important but not my dream TM. If that's the only thing then I have it, and I "WANT" something else....
San Francisco, CA
Though slightly adjusted:
Dirty carpets are numberless, I vow to save them
Truck Mounts dreams are inexhaustible, I vow to end them
Happiness with what you have gates are boundless, I vow to enter them
The content carpet cleaner way is unsurpassable, I vow to become it.
Hope this helps. somewhat amus
floorguy
Utah
Doug
You guys that still want vans, are the ones who buy the cheapest hookers to....
a Van...ppffftttt WTF is a madda wit you
damn at least one of them little 10' ones, so you can carry something more then a wand, and your lube
Ron K
Hey I can get a lot of Hookers in my Van.... and by the way what good is it if they're standing up.
tmdry
DC
Bill Martins
2 Dominators or C4's each w/ it's own burners in a 3500 high top 177 in wheel base ext Sprinter with dual side sliding doors.
Ryan
Sorry to hear that Ron. I've been there in the "too good to be true" deals also.
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
You're going to call other people cheap. :shock:
Chris A
OH
I won't buy a box truck unless a pole barn with a 14' door comes with it...
Jimbo
Here is one for you big truck lovers...
2001 W4500 GMC...42k mile...Diesel engine...Air Conditioning...Chelsea Power Takeoff Off supplies power to the unit...6008 Vacuum Blower...5" Vac Lines...dual silencers...dual heat exchange system, using both engine coolant and diesel exhaust. Brand new Blueline maintenance free divertor valve is included...though not installed.
175 gallon stainless steel waste tank capacity...112 fresh water capacity...also stainless steel. Blower and pto are both approx 2 years old. Hypro 2345B Pressure pump. Approx capacity of hose reel is 600'...Shelving and hose reels ARE included...200' 2" vaccuum line and 200' pressure line included...No cleaning wand included...even though they may be pictured. Patterned after Aerotech and Vortex units...the tanks were produced by Steam Action, and are known for there fine build quality.
Obtained from original owner/builder through purchase of company...I do not need this unit as I have another one. 14' Box is insulated in walls and ceiling, with a plywood covering inside the box...It also has a walk up ramp that slides in underneath...Box is 8' tall.
There are many good producers of truckmount carpet cleaning units...JUDSON ProChem...Hydramaster...Butler...White Magic...JCleanco...Powerclean Industries...Organic Compounds...Blueline...Sapphire Scientific...This unit for sale adopted many of the best features and rolled them into a dynamic truckmounted unit.
Tires are about 75% Brakes about 40% Will have new windshield installed.
No trades desired. No financing offered. Scams scorned. $16,000 Price is Firm. Selling truck and equipment only. Jim 775-250-0796
http://reno.ebayclassifieds.com/trucks- ... ad=6504768
Roots/Dresser 68-U_RAI...here is a link to the operating manual...http://www.rootsblower.com/documents/UR ... b-2002.pdf
This link might give you an idea of home much chrome you could pull off a trailer hitch with this unit...http://www.rootsblower.com/documents/UR ... cetble.pdf
http://cgi.ebay.com/2001-GMC-W4500-PTO- ... 45f6ad5d42
I love the Butler Box truck, but I'd like one with a more powerful van.
I'd also like bigger and better vac hose reel.
Jim Martin's tricked out camera system so I don't smash up anything.
Seats like and the interior like Art suggested.
Through in a nice sound system to connect my Ipod and lap top to connect to MB!
floorguy
Utah
Doug
hey i will pay the price for QUALITY and LONGIVITY :shock: :shock: :shock: :shock: :shock: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
tmdry
DC
Bill Martins
I do that with my IPAD in and out of the van. :mrgreen:
