Daily reports...
Fat Mike
Mike G
I’m remodeling a place but we just got several losses to manage. We’re already a bit overwhelmed. One thing that’s helped us is late deliveries! They’ve been a blessing in disguise.
Reactions: Hack Attack
I had to get them to investigate a pump pressure problem ... among other things. Turns out they found an issue related back to the initial installation which solved my long standing problem of low pressure .
Reactions: Nomad74
So now you can clean tile?
Soooo then......you've been doing sub-standard work for a long time.....!
Payback is a bEEouch....huh?
I’ve been having to work harder then what will now be required to produce high quality results
Reactions: Fat Mike
You should have just pulled..... Uumm.......... Never mind... Probably better you took it in...
  • Eyeroll
Reactions: hogjowl
2 tomorrow... One large 2 story..and one 4 area...
After tommrow.. Going to part the truck until Monday
One of my very large schools called and wants to get everything done...probably set up for end of month...
Yep, I start one of my schools tomorrow. Vacation is over. Retirement is not. I go back to pointing😀
Reactions: Fat Mike
Fat Mike
Mike G
I was stuck framing walls today man I’m sore and ready to go back to pointing!
We had several jobs come in last week and we’re already swamped! Good problems.
Crazy thing is pretty much anyone in construction is overwhelmed our roofers are close to 8wks on some projects.
Fat Mike
Mike G
how old and soft are you, Cindy? :lol:
.LT.A.
Im young n fluffy, getting it done just sore. Prefer to spend my time not working! Today we will finish out an adjacent wall and drop ceiling. Then I’ve got to re run plumbing.
My bro n Law is wrapping up my electrical for a sub panel for a jacuzzi tub n water heater
Well, I’m insulating my shop, and it’s up and down,
up and down the ladder. Don’t take much of that to make you sore. #soresally
steve_64
So you pee like Chavez now?
What was the problem with the pump? Was it intermittent or consistent?
Long story
But they replaced both hoses to the heat exchanger and it solved the problem
Jim Williams
Jim Williams
14 jobs this week. Now time for a week in Paradise with my youngin and dog.
