CLEANING THE GOLDEN DRANGON WITH THE NEW NORDIC1
Bjorn
v]http://www.youtube.com/watch?v=72Jwj6hD_5wv]
v]http://www.youtube.com/watch?v=geOOjd60UQEv]
v]http://www.youtube.com/watch?v=EGjoax4n64ov]
v]http://www.youtube.com/watch?v=sZMXxp7dsMwv]
This is the real deal 9.6 amps per leg no shit
all compents get equal power
after running for hours the plugs in the wall even stay cool no over heating
I use 10 guage cords
400 psi
8 flow on a 4 jet green green horn wand with hole glide
all heated with a little giant #3
This is the first time I have had this unit out doing real cleaning today.
everything is working like it should and I am very happy with the way things are turing out.
randy
USA
Randy
Plus the dependability factor, Zero need for a repair facility and lower acquisition cost. If this thing keeps progressing I might end up wanting one.
Bjorn
7]http://www.youtube.com/watch?v=za66MDwHkxo7]
here is the last
shows pump pressure and while in use
when you set this at 400 it's at 400 this is with 8 flow 4 #2 jets
Bjorn
not sure how much it weighs I instaled in the van by myself
I would say just under 200 pounds more or less a little
thanks
T
rotovacguy
Man, that thing rocks!! Nice job, Terje.
9.6 amps per leg? Cool, even in old outdated homes power wouldn't be a problem.
Brett
What size vac motors do you use, and do you have 1 vac and pump on one cord and the other vac on the other cord. Just trying to figure out how you come out with equal 9.6 amps per cord. Thanks for the video, fun to watch.
Lefty724
Monterey County, Ca
E
Nice unit indeed Terje!! Couple of question though:
1)Were the 2 10 gauge cords running off of the Golden Dragon's power?
2) Does your machine come with a waste tank?
3)Are the 2 cords different styles on each end (standard 3 prong on one end, and twist and lock ATM)?
Thanks, I like this machine more and more every time you post pics and vids!!
Bjorn
yes 10 gauge cords bigger
hubble twist and locks 20 amp rated each
yes ran off the restaurant power
yes it does come with a waste tank the one in my van is a modified prochem tank which I welded a new bottom on and new powder coat, I have not finished my new tank for this machine yet and it will look like this one
I haven’t seen any of the other electric truck mounts in person, but one thing I like about Terje’s is the welds are really top notch and everything is extra heavy duty.
Brett
My 2 Honda 2000 watt 45lb generators could power that and you could still easily transport them for other uses like portable use, camping etc. 9.6 amps on both cords is very low for the performance that it puts out. Thats lower than my recoil with 3 cords except the 2 stage cord that Ed shows as 8.6. amps. and the Recoils pump is not as strong.
Jeff Madsen
Lincoln, NE
Jeff Madsen
That's a fantastic looking machine!
I'm worried about the unit freezing while cleaning in the middle of a Nebraska winter. With my slide-in TM the unit generates a tremendous amount of heat - unless the doors and windows are wide open, nothing will freeze even if it's stupid cold outside. Anyone have thoughts on this?
rick imby
Montana
Rick
hubble space Station is where I am from. Someday Me--Terje-- get to go back home and be with ET. I am building this test UFO and I call it carpet cleaner to confuse stupid humans. I hook up to electricity but it really powered by terjitonium....
Looks good!
How big a tank is that? Will it need to be anchored to the wall or will the feet be enough to hold it when filled with waste water. Can you cook chili in there too? :p
Poway, Ca
John LaBarbera
That is a GREAT PICTURE.
steve g
herriman, UT
steve garrett
that machine I must admit is impressive for something that runs off 2 plugs, however IMO it does not look like the power really is there for serious use. the vac sounds like my unit when something is plugged or I am running 300 feet of 2",
odin, that is the craziest wand stroke I have ever seen looks totally random, kinda like something a new guy would do :lol: I dunno if its different because you are filming, on second thought you might have been doing it one handed with camera in hand
Bjorn
one handed while holding the video recorder .
let me guess your the kind of guy who sees a picture of a knock out women and will only notice the candy wrappers on the bed spread.
harryhides
Canada
Tony
Jeff, that is a valid question and since I live north of N.Dakota in probably one of the coldest parts of the continent, let me try to answer.
We used to insulate our vans and go to great lengths to prevent freeze ups INSIDE our tm's and found that open doors or wind direction were much bigger concerns. Then we stopped insulating our vans - with no increase in freeze ups. Then we switched from Burners over to Heat exchangers and still no problems.
Now with Odin's unit and a Propane little Giant heater we still have had no problems. Those heaters throw off a lot of heat - much more than HX. A van with a rear heater will help. We also try to keep things off the floor - we have a table built over the fresh water tank that works well and when it's super cold will store lead water lines up in front of the passenger seat to get some extra heat, while driving. When it is very cold and we are out cleaning we may fill the fresh water tank with hot water which serves as a source of passive heat inside the van. However we will usually not clean on those super cold -30 days. Or we will take our Thor unit out of the van and use it inside as a Porty which is what we do with commercial jobs with no easy hose access.
Hope that helps.
Latest Auctions
