Chem meter is rising when off the trigger
JS41035
Diaphragm. That's why that ball valve on the 870 and 2500 are nice. Order 2 when you get them. Because as much HP stuff as you do you'll need it. Out to be a 10 buck fix
1/2 inch swaglok check valve coming out of e2 exchanger is bad, replace it and good to go.
Reactions: dgardner
Mark Saiger
Mr Happy!
Mark Saiger
On the Butler it can be the Chem injection pump diaphragm with a bit of wear or hole but I have also found the pressure regulator can cause this trouble too
Jim ran himself off.
we both know that is not true but it is what it is...
@dealtimeman knows the answer.
Actually he had to call me to get the answer because he did not even know there was a check valve there....
If you get this one from windtrax......you will never ever have to worry about it again...thats what I put on mine...
Fvckin Lockheart, what a failure...
Thanks Jim!
As soon as I saw the diagram I recalled that part and its function. I had that one you got...
It failed too..
I know what you mean, if he will do that to the nicest of guys, imagine what he will do to the bad guys.
Sheesh
I've gotta agree with Jimmy.
Pussified, you fookers would be. :yoda:
