Changing oil roots 47
Dwain Ray
When giving advice i try to lose as much techno mombo jumbo as possible to get the information across and sometimes i dilute it too far. For those techmo geeks this one's for you
Reactions: Johnny
Johnny
Johnny
According to Dwain's chart, Amsoil Severe Gear SAE250 is too heavy. I would just order some Aeon, but it appears my distributor is closed for the holidays, as is PD Blowers.
I have some Amsoil Severe Gear 75W-90, which is too light.
Will try mixing 250 with 75W-90 for now. Or pick up some quality SAE 90 gear oil.
Thanks, Dwain!
Don't ever follow my advice or you'll end up a BDCC!
icleancarpetz
Rafael Samson
my 47 has been very good to me since 2003. I bought the high heat roots.
drained, cleaned her up, refilled…sounds and sucks better then ever. A few extra bucks for oil verses $3k plus new replacement well worth it.
Was quoted $1,200 to drop off and have my 47 serviced/rebuilt. my have it done at some point but runs great at the moment.
Johnny
Johnny
Where do you buy Roots oil? I don't dispute the wisdom of using the best when you can find it.
Dwain Ray
I think now you're just splitting hairs now if you look at the picture of the aeon bottles 1 says gardner Denver which is sutterbuild it's like pump oil , i have a hypro pump but i use cat oil in it instead of hypro oil because i can get cat oil from home depot and id have to special order hypro , it is more important the frequency of service intervals than which brand of blower oil you use when i built frankinstien i retired a 47 blower that was new in1991 and passed down thru 3 machines and has approximately 14,000 hours on it but i changed the oil in it every time i changed the pump oil 500 hour intervals
icleancarpetz
Rafael Samson
why did the cool purple need to retire? Couldn’t it be rebuilt? Cracked housing?
Dwain Ray
View attachment 119762 View attachment 119763 View attachment 119764
It doesn't need rebuilding it still runs fine, when i built frankinstien i wanted a new machine . Not another machine built from used parts. Properly maintained The machine i built has a life expectancy of 20 to 25 years. It is replacing a 23 year old steamgeni pto(now delegated to be a backup machine) , this machine is solid stainless steel construction, 50gallon wastetank ,machine tins and custom filter box no brass fittings all stainless. It started life as a 1998 steam geni 45 pto it has the best of the best cleanco engine mount with steamgeni drive shaft Cleanco's water to water heat exchangers with hydramaster salsa afterburner, prochem/comet waste pump ,hypro pressure pump roots 47 blower, prochem/general chemical pump, custom electrical distribution prochem waterpond with modified mytee shelf across back custom narrowed side shelving custom modified crash screens all installed in a 2020 chevy 6.0L extended van all pieces custom powdercoated no paint all in chicken feathers everything $61,000
20190131_174531.jpg 20190326_153000.jpg 20190417_175331.jpg 20190517_165737.jpg 20190717_170644.jpg 20190726_125938.jpg 20190804_153148.jpg 20190906_104549.jpg 20190908_165843.jpg 20190908_165942.jpg 20190908_170147.jpg 20190908_171102.jpg 20220108_172210.jpg 20220123_115908.jpg 20220321_100043.jpg 20220402_190553.jpg 20220402_120006.jpg 20220404_132854.jpg 20220501_123800.jpg 20220502_175831.jpg 20220513_145305.jpg 20220515_132426.jpg 20220519_195505.jpg 20220707_181159.jpg 20220721_172112.jpg 20220723_190331.jpg 20220925_125043.jpg 20220925_125139.jpg 20221101_120314.jpg 20221101_125018.jpg 20221216_130352.jpg 20221216_134622.jpg 20190422_153248.jpg 20220213_152744.jpg 20220213_152626.jpg 20220213_152952.jpg
Dwain Ray
View attachment 119766 View attachment 119767 View attachment 119768 View attachment 119769 View attachment 119770 View attachment 119771 View attachment 119772 View attachment 119773 View attachment 119774 View attachment 119775 View attachment 119776 View attachment 119777 View attachment 119778 View attachment 119779 View attachment 119780 View attachment 119781 View attachment 119782 View attachment 119783 View attachment 119784 View attachment 119785 View attachment 119786 View attachment 119787 View attachment 119788 View attachment 119789 View attachment 119790 View attachment 119791 View attachment 119792 View attachment 119793 View attachment 119794 View attachment 119795 View attachment 119796 View attachment 119797 View attachment 119798 View attachment 119799 View attachment 119800 View attachment 119802
Forgot, the control panel is 24k titanium gold plated polished stainless steel sent to Nova Scotia to be lettered, they were the only company to return my emails about silkscreening on 24k gold
Reactions: Dolly Llama
Probably how it should have been done in the first place.
Dwain Ray
The steamgeni pto is and was a great and highly reliable machine, but i want to do tile and grout and the heat exchangers won't handle the pressures necessary for that and thats what started this whole project, i looked into buying a new machine to do tile and grout and was very disappointed with what is out there, as it stands my 23 year old steamgeni backup machine will probably outlast anything on the market that i could buy now. It was my supplier that convinced me to build frankinstien i started building 2/19 finished the machine 10/19 started looking for a van then covid hit 2/20 bought the van 12/21 started the installation 1/22 completed it and put into service 9/22 have about 200 hours on it so far
icleancarpetz
Rafael Samson
Holy Mack! Call him Dr Ray!
nice man. Really freakin nice. Thanks for sharing.
if you like further inspiration….check out ‘Frankenstein Chronicles’ playing on BritBox. Think you will like it.
Reactions: Johnny
All I know is non-detergent oil, and use oil with Zinc in it if possible.........?
Look at the big brain on Nate.....very
Good.....however I used 30 wt non-detergent for over 40 years...never lost one....gave one away once tho!
Dwain Ray
But the genies never turned over what...15-1600 rpm's?
Olive oil probably would have sufficed.
The driveshaft turns about that, frankinstien is set at 1300 engine rpms driveshaft rpms are 1850, blower is 2950 and that is around the same for my stock sg 45pto. Other steamgenis were screamers the hydro 1 & 2 spun the blowers at max 3600rpm. The hydro1 had 2 blowers in series one blower rammed air into the other, blower #2 got really really hot. The blowers on the 1&2 where pretty small back then , sutterbuild 3m
Dwain Ray
I think im gunna drop out of this conversation at this point, as for me an ounce of prevention is worth a pound of cure , i put chevron 91 in my shelby and aeon in my blowers,if you run anything else and it works for you great,as for me good gas and oil is really cheap insurance, after all, your only as good as your tool
icleancarpetz
Rafael Samson
thx for your input bro....stay in touch.
KevinD
Kevin Dumas
Local here had a twin 3m setup back in the 80's
KevinD
Kevin Dumas
What kind of Shelby? I have a 14 GT500.
Came close to trading it on a new one but couldn't give it up.
Dwain Ray
I have a 07 shelby gt California special 1 of only 101 build and 1of only 1 built white with medium parchment interior . It was my 30th business anniversary and 60th birthday present to my self i bought it new in 2007 my 30th year in business and made the final payment on my 60th birthday
20180930_123244.jpg 20180401_151133.jpg 20180930_123229.jpg IMG_20210401_211329.jpg
Dwain Ray
Depends on who you talk to as for me i know no other machine my first machine was a rinse n vac rental i stepped up to a steamgeni 731 portable in 1978 then to a new 733 portable in 79. 83 i bought my first and only new truckmount a hydro2 then a used hydro 1 then i started with the pto's in 1999 i briefly owned a sizzler but bought it from a competitor fixed it and flipped it, then when steamgeni went out of business a friend of mine in Sacramento was a distributor and ran 7 steamgeni pto's and replaced 1 of his machines every year i made a standing offer for his entire fleet. Nobody wanted um then. So for me steamgenis are great in 45 years of business they have only broke down 4 times that i couldn't finish the job, once my hydro1 burnt a set of points on the onan, on the hydro2 they bolted the pump pully to the vacuum pully and i sheared the bolts, once i sheared off the end of the driveshaft on mt 1991 47 pto and once a transmission went out while cleaning also the 91 i dont think their is any other machine on the market today that can top that, sure ive had breakdowns other than that but with the parts carried on the van i was able to continue working and finish the job, my nearest supplier is 5 hours round trip away so im pretty self sustaining, im regularly 1 or 2 hours from home base, this picture is of frankinstien's onboard spare parts locker belts hoses and brass fittings spare wand valves, bypass regular etc. etc.
FOJL
It really only matters that you don't massively overfill, or let it run dry.
Reactions: Johnny
