I don't know that machine but on older Prochem units a temperature solenoid controls bypassing water. It would bypass when too high a temp. It would also if scaled up and needed cleaned.
There is also a bi-metal thermal valve in the water box that if it got too hot would dump into the waste tank.
Are you referring to the temperature sending unit on the check valve?
As for the thermal relief valve…I’ve got it temporarily disconnected until I find a hose to connect it to the waste tank
No, it was usually mounted on the frame on the right hand side, facing the unit.
Another challenge completed today thanks to @Jim Martin
The temp kept dropping when I let off the trigger. Jim came to the conclusion that the check valve in the pressure regulator had to be in it. And it was. So I took it out and it’s holding heat just fine.
I forget why some truckmounts need them and why some don’t, but it’s a good thing to check first if your tm is doing the same heat loss.
Looks like my brand new vac gauge went bad on first real Cc test
Any ideas on how to fix? I pulled that plug off the top of it and it’s still reading that
  • IMG_3998.MOV
    111.5 MB
Justin Johnston
What does the vacuum gauge read with the machine off? What about at full RPM without hoses connected, and neither vacuum port blocked?
I had the vac set at 14"under full load
You see on the video that it stuck at 17 for some reason. It stayed after I disconnected the hoses. And
Justin Johnston
Stuck at 17 could indicate a stuck vacuum brake. Is it still reading 17 now with the machine off? Do you still have the plug off of the vacuum gauge?
Yes, it still reads 17 after the plug is off of the gauge. I think it went down a little to 15
I just cranked it and it's not reading anything when under load now. I guess it's just bad
Almost ready.
Did a couple needs today to get this machine usable.
Hey Fred, can you put somewhere in my thread title “Money Pit”?
Purchased the van originally for $7500 and before all this is finished, $13k should be the finishing cost of van and machine.
2D65EAD7-F580-42ED-BF60-6561F71A791D.jpeg F1BDEC19-DF39-4789-86A6-BDBFCEEC56FE.jpeg
Almost ready.
View attachment 111632 View attachment 111633
If it runs strong for years, you're money ahead.
Delivered a rug this morning and collected $600. I surprised my wife with a 75” TV. Then fixing my APO float. After that taking my boys to see Dune. What a day.
Hope you get it fixed soon. Wish me luck. I’m getting the Lima Bean Special smogged right now.
The oil switch just got fixed today
I urge anyone who has the Hyundai engine to buy another oil pressure switch. The original one is plastic and made to fail, due to its location on the block. The new one isn’t plastic
My van didn’t pass smog. It passed the sniff test but the catalytic converter isn’t a California compliant one. So its costing me $800 to swith it out to a commie converter.
Man, if you haven’t figured it out, we’re just money conduits. Buy new, buy used, no matter, or what you do, keep it flowing!
