Blower is clanging on cold start
bmxin
dayvaad
Hello just thought I'd check the resources here to see if I can salvage blower...
Basically on cold start there is clanging noise (bearing?) coming from the blower after about 15mins when it's hot enough goes away. Throughout this there hasn't been a performance dip. 250 hours on Aeon Oil, site glass is center filled
My plan was to disconnect and take out and perhaps get a 3D view from Legend and inspect.the cog/belt to see just how bad this is
Aside from ordering a new blower
Are there other protocols?
Thank you
My first check would be the belts to be certain there’s no belt slapping
It has the same noise that you’re hearing. And the noise going away after it warms up tells me that the belts are grabbing the pulleys better and not slapping anymore
Reactions: bmxin
FredBoyle
Fred Boyle
Role
Years of Experience
38
Belts are a good place to start but I’ve experienced the harmonic rattling caused by belt slippage when the blower is under load not on startup
I assume you have done a thorough hot water flush of the blower lobes
Reactions: bmxin
Thank you
what unit?
Reactions: bmxin
bmxin
dayvaad
what unit?
13' Prochem Legend GT.
2800hrs
95hours on OEM replacement Kohler.
I've only had this neglected tm ~1000hrs. I've just done blower oil/pump change 3x, descale 20x
I have not sucked up a couple buckets of soap in a minute. I do follow vac/lube @end of job by blocking off inlet while spraying WD 4sec and running with load 60sec then run without load for cool down &evaporate WD
Is there a different method to flush blower?
2800hrs
Don’t buy a blower yet.
The fact that it only clangs cold, then quiets down once warm, with no performance drop, makes me suspect belts/pulleys/misalignment before internal blower failure. Check belt condition, tension, pulley alignment, and blower mounting first.
Since the unit was neglected, I’d also do the Butler flush method before condemning the blower — hot water with a cleaning agent through the blower at idle, in a place where the discharge won’t matter.
If it still does it after that, then start checking for shaft play / bearing wear / timing issues and plan on pulling it.
I also wouldn’t count WD as true blower lube — more moisture displacement than lubrication.
You never mentioned refilling the grease ports every 100hrs with about 5squirts of grease. Have you been doing that?
Reactions: bmxin
bmxin
dayvaad
Yes thanks Tim that was overlooked by 200hrs and filled
I'm going to take off HX and soak in simple green, remove brake off blower and pour diluted soap, and ordered hi temp belts as the Belt definitely has too much stretch currently.
When this is all back together I'll let community know.
The last option I had was to get an x ray view inside blower by disassembling and if an obvious cog/belt issue I know of a fabricator...But are there successful experiences with blower rebuilds?
