- Joined
- Jun 7, 2014
- Messages
- 345
- Name
- kevin
Well got my 1st tile & grout job in the books. Only did it cause it was a repeat customer for cleaning his carpets and he really wanted it done. Don't have a spinner tool or high psi portable only have a Mytee M5 with 500psi. Sprayed cleaner down with pump up sprayer, let dwell, used grout brush on a stick to scrub grout. Put the stiff bristle brushes on my CRB and went to town, then used a hard surface wand connected to my portable. had to only run one vac motor, using both was two much suction, hard surface wand sucked and get stuck to floor could not move it. put hot tap water in solution tank hooked my mytee hot turbo heater then just rinsed and sucked it all up, came out great customer loved it and payed me $20 extra and it was fairly easy to do. Think I just might have to do this more often but will be a little selective of the jobs i take. Love my CRB on carpets and now on floors too. However would not be good in tight space's, no way your fitting a CRB in a bathroom and getting around the toilet. So i'll just stick to big open area's for now
