Zipper results
cape coral fl.
jack zerkie
Thanks Eric tried the Zipper on two jobs . The first was a office glue down. I used the wand with a glide on part and the Zipper on the rest. The Zipper was drier and cleaner. The next job was a empty unit small house with a off white berber. I used the same things that I always use and the carpet was very dirty. The results were wow and easy but I do have to learn to stand behind the Zipper and it,s easier tha the wand. The Zipper gave my unit more vacum and increased the water temp. from the heat exchange. I hope to have a great honeymoon the the Zipper and will keep you posted.jz
cape coral fl.
jack zerkie
The flow rate is close.My TM is a Cobb 2045 with Larrys Two jet 110-03 with a glide. The Zipper has 5 jets 1.5 each,but the weight of the Zipper and the two glides seems to increase the vacum. jz.
Erik
Michigan
Erik
Thanks Jack, glad to hear it's working for you. It is a little of a learning curve, but you will become a Zipper master in no time.
P
Phoenix Phil
How long have you had Larry Cobb's 20/45 and how do you like it?
Utah
so that would mean he went up
6 vs 7.5
lance
Zipper master.....
Eric, that just doesn't sound right......if you know what i mean. :lol:
lance said:
Zipper master.....
As long as you don't get the beans about the frank, your all good!!! Lmfao!
7]http://www.youtube.com/watch?v=Ek3XKF2GcjE7]
