wtf split -What's the truth with Carpet "Sanitizer"?
Numero Uno
Ma
Caesar
First stay safe any one who reads this.Not enough time to pm.
Ok,not a diatribe just facts as I see them.
Is it impractical to do as they recommend,possibly...But
Failure to do so puts you in a legally bad position.Any admission as stated above that you do not ...Well you worked much to hard to have a loophole emerge...IT IS. !
Back to carpet cleaning front line's.It is a special situation,charge accordingly or do not do it...
The extra times are never needed in your daily week,but for this -Yes...
Your a service which provides value...You have too...
Also the residue left behind in that amount as the original chemist's new needed a re rinse-provide it,what are the side effects to pets/people/etc are ?
Your liability...Do not be the one carpet cleaner in the newspaper,that the sharks here will devour also...
Be smart bud-good luck,hope some where up above some cleaner helped ya.
That's Why Mike started this ...CSR-2020...
  • Wow
I explained to Marty that while daddies sometimes do put a fluid in mommies' bodies in the space between their legs, it is not pee. It is a very special fluid called semen that sometimes can cause the mommy to grow a baby inside of her. He said, "OK, Mike."
