See what I meant about excitable.Mikey P said:Well Ofer, if you were not so excitable you would have seen where I wrote ONE SAPPHIRE TRUCKMOUNT and used your deductive reasoning to assume it would be used to rinse the carpet.
and I'll try and contain my excitement when I rub my winnings in your face.
Did we forget to mention that MeAt is an arm dealer? shiteatinggrinMike Draper said:Meat, get ready to pay up sucka!!!!!! I'll take the $100.00 now if you want to back out early without the humiliation.![]()
Brian!Brian R said:Can't we have a side side bet that neither of the two idiots doing the cleaning will increase their manhood by cleaning "better"?
Good God Girdy. :roll:
AdamHale said:The results will be close to the same if the equipment is ran correctly. However, the RV will do it faster and WAAAAAAAAAAAY easier!!!!! Faster because you aren't dragging the 175 out of the truck.
Mikey P said:meAt, bring only sections that are embedded all the way to the scalp.
we'll cut it up into two equal sections, weigh them each, let them dry and weigh again
and trust me, there will be a clear winner there.
Mikey P said:we'll cut it up into two equal sections, weigh them each, let them dry and weigh again
Mikey P said:only hacks get by on appearance Larry.
Mikey P said:still time to back out bud.
