What is the advantage of Stainless HX?
Unless it's a different design that holds more heat, it seems to me that it's able to have a less chance of freeze damage. It might hold more water pressure if it uses different fittings, but that really doesn't matter if it's the same water pump. I think you got an awesome truckmount at an awesome deal, so I wouldn't be too concerned
TConway
Thomas Conway
More pressure, ss does not transfer heat as well as copper tubing, but does handle low temps better, but no matter what a bad freeze can wreck em all
