Waste tank gasket, wear to buy?
carpetcleaner
Gilbert, AZ
Rob Litwin
If it is the foam tape I don't know.
If it's the black "c" shape that fits on the lip of the tank, I replaced mine with some sort of car door edge guard that cost less than $10 for a roll big enough to do the waste tank 3 or 4 times. It seals good and hasn't worn out in over a year.
if it has a flat edge on top, a 1/4 bead of silicone .
I'll explain how to do it, "IF" you have a flat edge on top
l.T.A.
l.T.A.
No Larr...if it's a flat edge..use a pickup camper seal...completly dry the area
and adhere wit weather strip adhesive...black not yellow!
