VCT VS Vinyl/Linoleum
J
jstucky
Looked at a Vinyl for a gal. She has had it stripped and waxed before.
Do not have pics at the moment.
I believe it was sheet vinyl and not squares.
Is all vinyl have a pre-finish on it? And can you not strip and Re-Coat those that are pre-finished???
Instead of 3-4 coats like with the VCT, do u just single or double coat??? And use same type of wax or do u need a special wax for linoleum or pre-finished floors?? I guess I'm just wondering how wax sticks or soaks into regular Vinyl. I have only stripped and waxed VCT
She said it always shines when they are done. Didn't know if they just put a spray buff on or actually waxed.
Thanks!!
Jordan
GCCLee
Excellent Question!
What machines, pads, chem choices would best serve this purpose?
its all about the same....but on vinyl it shines a bit quicker due to the fact that that its not as porous as vct....
also does it have continuous coving??? cuz then edges would be a biotch
J
jstucky
Continuous Coving being uneven floor with low spots??
Are you asking my equipment Chris??
I have 175 with all different pads and bonnets. Mop Bucket etc
500 PSI porty
Soon to be TM
Shane Deubell
Depends if you are talking newer armstrong sheet vinyl or some older type. The newer styles we have run into state no black/brown stripping pads, less abrasive like blue/green. They can be left alone or finish applied but we keep it light 1-2 layers of finish.
steve frasier
continuous coving is where the sheet vinyl extends a few inches up the wall
just don't be to agressive with th stripper
if the floor finish is real shiny or thick, beware of mop and glow type products
