Truck Mount Manufacture HAS
J
Johnnyone
Now has adapters available for the 2.5 Vacuum Hose to fit to your waste
tank for High performance water recovery.
If you also want add a stainless steel prefilter that will fit a 2.5 inch hose
they have them available too.
Thank You Larry Cobb
are those a good 2" on inside diameter?
I went to the twist cuffs to eliminate that bottle neck created by the hose connectors.
I need a 3" to 2.5", then a 2.5" to 2".
J
Johnnyone
If it was a barbed fit on the 2.5 in it would be better
It is a 2 inch on the OD and less inside
Ron do they make a kool cuff reducer to fit a 2.5 to a 2
