There are no stupid questions...
Meter Maid
The Undetective
Dayton,Ohio
Except this one:
When people say to run a rotary at 300 psi, is that with the trigger pulled or the psi setting on my TM?
I ask because there’s about a 100 psi difference from the setting on my TM when I pull the trigger.
Meter Maid
The Undetective
Dayton,Ohio
That’s what I was thinking, especially if I’m getting only 200-220 with the trigger pulled.
I thought you were Chavez.
friction loss
and I'm not sure if people adjust their rotaries keyed.......
manual for 360i says 50-300 psi......I'd probably raise it (keyed) provided you are getting good recovery and saw better results
*lowering the jet size/flow will decrease friction loss.....some also have a flow control valve
Reactions: Meter Maid
Meter Maid
The Undetective
Dayton,Ohio
friction loss
When you say “keyed” do you mean increasing my psi at the TM to allow for the loss from friction when I open the trigger?
Reactions: bob vawter
yes
I am saying that is the reason for the drop and that you could compensate for it
not that you should....
scotty747
I just crack the shut off valve until I get water. Then add more pressure if you need it. No need to soak it unless its trashed.
Trip Moses
IMOL
Savannah GA
Trip Moses
Except this one:
Always set your pressure and your chemical meter with the trigger pulled. Come on, Man!!
Papa John
Lifetime Supportive Member
San Francisco, CA.
John Stewart
My understanding Is that if you are getting a 100 psi drop when the trigger is pulled then the pressure regulator needs to be replaced.
USA
Matt Middleton
I installed a needle valve right after the Trex quick coupler. Then I can easily control the amount of solution hitting the carpet. It really made a difference to our cleaning and dry times.
