The swirls
San Francisco, CA
It's the metal boots. Temp around 230-240.
Guess we need to back off a bit.
Thanks!
You're welcome. You may need to reduce temp more than just a bit as the metal can get quite hot. Just experiment with different temps and also with how long you hover in the same area.
Old Coastie
Heart of Dixie
Stephen
I find some carpet can take a set just using household hot water. Mike nailed it: 360i in, wand out. Groom immediately if the swirls still show.
encapman
St Petersburg, FL
Rick Gelinas
I agree with the comments above. A CRB can be used (while the carpet's still damp) to remove the swirls.
If the customer has no regard for a modern-art swirl creation. 🤣
My suction hose picks up the rats while I'm hwe, because it's dumb to crb after you clean. When did marty get in to this mentality? Last I heard, his crb is collecting dust in his office
Loren Egland
Antioch, California
Loren Egland
526F82E6-B855-4AED-8FCC-BD16796494A3.jpeg36E278B4-F75A-45D5-B9BF-760D21A2D144.jpeg526F82E6-B855-4AED-8FCC-BD16796494A3.jpeg
DAT
Nevada
Bill Cheryl
Ahh yes. There's nothing better than running a dirty beater bar vacuum over clean carpet after it's been cleaned.
I have 2 vacs... I actually have a dedicated vacuum for post vac for that reason. I dont like using dirty vac.
icleancarpetz
Rafael Samson
“Thats the trade off Mrs Home Owner. I can clean your carpet superbly with this machine pulling out what no one else can or i can clean like stanley steemer and get ok results. Which would you want Mrs Home Owner? “
you guys are nuts for grooming or wanding after rotovac’ing. Too much work unless its a home run grand slam job.
