Jan 12, 2015 #1 Mikey P Administrator Joined Oct 6, 2006 Messages 116,042 Location The High Chapperal They finally figured out that we dont want to have to remove the phone case every time we need to swipe a card. This new one has a flexable bottom and the prong is long enough to work with most cases Reactions: Mark Saiger
Jan 12, 2015 #2 Lee Stockwell FOJL Joined Oct 7, 2006 Messages 18,851 Location Benton KY USA Name Lee Stockwell I've gotten out of the habit of using the swiper, too glitchy. I'll see if that works better.
Jan 14, 2015 #3 sweendogg Member Joined Jan 15, 2008 Messages 3,534 Location Bloomington, IL 61704 Name David Sweeney Its not long enough for the Lifeproof case :/ oh wells. Reactions: Mikey P
Jan 14, 2015 #4 J JS41035 Guest I keep a Male to female Aux extension with my Ipad in a lifeproof case. about 2 feet long . plug your Square reader into that and it makes it alot easier. Reactions: Mikey P
Jan 15, 2015 #5 sweendogg Member Joined Jan 15, 2008 Messages 3,534 Location Bloomington, IL 61704 Name David Sweeney that is what I do as well.
Jan 15, 2015 #6 Doug Cox Supportive Member Joined Dec 17, 2006 Messages 4,884 Location Delavan, WI Name Doug Cox I've used that one as well and it has never fit without opening the case.
Jan 19, 2015 #7 Larry B Member Joined Jun 23, 2008 Messages 2,903 Location Pigeon Forge, TN Name Larry Burrell We just got 3 and they have worked fine on the newer lifeproof cases but still not on the 4s and 5 lifeproof cases
Feb 3, 2015 #8 N NobleCarpetCleaners Member Joined May 16, 2010 Messages 1,191 Name Noble Carpet Cleaners I too have been using the screen cause 2 of them got stupid glitchy. Newer one looks worth a try.
