Technically speaking………………
C
Cameron1
and without using the words, “oxygen bleach, chemical, or oxidizer how would you explain to your client the process and procedure of using osr to treat Urine. Just curious
I don't. I just do it and get paid.
If you gotta explain it, then you're not very well respected by your "client."
Steve, I wouldn't, I'd just use some Quat-a-lot and forget about it, follow with some O2 pre-spray and get rid of the yellow in the process.
OSR is so 2000.....lol
Steve;
The best solution is to saturate the area with:
1. An Oxidizer (which breaks down the urine deposits so they no longer release odors)
and
2. a oxygen-compatible actual Enzyme
Extract with claw and then DynaCide or HydroCide or another "Cide" type product.
Out of Character - 0
Jesse
Cleaning the pad and backing?
Maybe add "as best as we can from above"?
I try to answer technical questions with just a smile or a comment like Gary made
Oxidizers like OSR and Pet ZONE could be described as having an effervescant action. Or simply as rapidly accelerating the natural process of decomposition.
Scott Warrington
