Stain Zone.
Doug Cox
Delavan, WI
Doug Cox
Is there a shelf life on this product. I assume there is but I want to verify it before I pitched it. And what do yu guys do with all the chems you buy and never use?
ACE
Lawrence, KS
Mike Hughes
I try to pawn off all the chems I don't like on friends. stainzone is good stuff but I can't tell the difference from it and sallys 30 or 40 peroxide (other than price). Yes it has a shelf life 1 year tops if unopened and stored at a cool even temp out of sunlight.
John Olson
Orem UT
John Olson
Depends on who you ask but I can tell you that since it came out I hardly sell any stain magic. Stain 1 has pretty much killed it.
The sulfur dioxide based reducers are very effective, but a little smelly. I like VacAway's version best because it seems to smell better than other one part products.
I thought StainZone was an oxidizer.... :oops:
it sure as heck does STINK though
Doug, every year or two I have a "dump off" of unwanted or unused chems
If it's been on the van for more than a year.....it's dumped when we pull everything out to pressures wash the inside .
If I think it will kill grass, I pour it in the drive and/or around the base of the pole barn ...
it saves on weedeater line and/or vegetation killer juice .....
Shelbyville TN
StainZONE is an oxidizer and does not contain sulphur dioxide.
Ace hit the nail on the head with his answer on shelf life. It is importnat to note that keeping StainZONE or any oxidizer away from heat is important. Fresher product works better. Both heat and time will degrade an oxidizer.
