Shower hack
Russ T.
Russ Terhaar
I've got all day tomorrow to work on 2 showers. We've had a business relationship with this couple for years because we handle the carpet cleaning for their property management company. I smashed the carpet for them on the first trip last week. She was eating out of the Kid's hand.
Then I did a test on her shower and failed miserably. I brought a knife to a gun fight, I think. I called Mike because I knew he'd know the spot to get me some strong acid...
Well, delivery came today and I texted the homeowner to confirm for tomorrow morning. She's excited. I'm actually afraid a little, she's so excited. I want to crush this shower tomorrow. When I'm done at her place I'm going next door to her mom's house to clean her shower. The ladies are already starting to talk and I'm no shower guru.
I want to crush it, like I've seen Mike do. I got caulk and everything.
The shower is caked with hard water on the ceramic tile and grout. Also the glass door. It's awful. I think she said they built the house 10 years ago and they don't have a water softener.
Help this shower hack out! I will do what you say!
I've got the strong acid, wire brushes, utility knife, the Mikey's Board Grinder hand tool...
I want to have a good day tomorrow and really impress these ladies. It's a very prominent family in our area and this is a good opportunity for us.
I tried to get a pic or 2 to load but the image is too big or something. I took the pics with my fancy new camera.
Help me guys!
Reactions: Bob Pruitt
Hack Attack
Dan
easier with an orbital but steel wool works too
I carry both
not me in vid btw just had quick look online
Reactions: Russ T.
Russ T.
Russ Terhaar
Maybe now is the time for me to get an orbital!
I need that tile and grout to sing too!
Do I need to tape their dark (maybe nickel) hardware off?
Hack Attack
Dan
depends on what you mean by "strong acid"
muriatic? dont use it if your a noob
if what @Mikey P recommended follow his/label directions?
get a paste or compound for the glass, not sure what brands you have there
Reactions: Russ T.
Russ T.
Russ Terhaar
Do I need a respirator? I’ll e sure to wear gloves. Do I tape all the nickel hardware off?
Thanks guys
Although I've never really caused any damage with acids on fixtures cuz they're already usually trashed bring a container of Vaseline it just coat the fixtures that you're concerned about that's a lot more waterproof than masking tape which will get loose and fall off and drive you nuts if they're perfectly flat try the razor blade if they've got lump or are groovy or irregular texture you probably won't have much luck
Wandslinger
Tom Meyer
Excellent advice
Reactions: Mike Pailliotet
I've used rubbing compound with good results.
Why pay more for some fancy expensive " For shower doors" compound when cheap works just as well.
House cleaners will use lemon oil on the doors to make it look really clean and shiny...............till next time.
steve_64
Lemon oil is a joke. Not sure why so many people like it.
Viper renew on grout lines that are real bad and a good brush. I don't touch anything else with it.
Phosphoric acid shouldn't hurt hardware and will clean just about everything. Apply with a blue no scratch pad and scrub lightly. When it's all clean you will still see water marks on the glass. That's where you need the steel wool and more phosphoric acid. Work on small inconspicuous areas until you get the feel for it.
Wondering how this went?
