Question on VacAway Chems mixing with other chems???
jstucky
Jordan Stucky
I mixed VacAway Peroxcyllent to use as a rinse in a bucket at 1 oz per gallon mixed with Fabpro Kill Odor SR at 1 oz per gallon. It made white flakes and chunky stuff start floating on top of bucket and when I put in machine it clogs the solution suction hose screen.
This used to happen when I used Stop n Rinse also and Shatter so I stopped using it.
But I used Peroxcyllent as a Rinse the other day with no Deodorizer and I think it was fine.
What's going on here???
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
Its either that catonic, ionic thing going on. Or the deo caused it to coagulate a lil bit, and flake/seperate. Some deos have a form of alcohol in them, and when you mix them with other products, it causes that to happen.
Maybe Forsythe will be along shortly for the Webster definition of what happened.
VA does not play well with others.
All that plastic needs to be left alone.
If you ever find yourself hankering for some fresh Cottage Cheese mix some VA Encap with some O2.
jstucky
Jordan Stucky
exactly as mikey says...
i battled the cottage cheese in my fresh water tank a while back because some jobs i would use 02 and some jobs the shatter or stop n rinse
