Puked Up V-8 Juice
Hey Budd, SM is what I would use if needed after I hit it with an acid type spotter first then flush I mean extract and rinse..
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
Just look at the ingredients I don't see any dyes in it making it an organic stain. Stain Magic it is.
Lora Olson
Stain Magic first so you don't set in the stain. If there happens to be any dyes in it, then can go to Red Relief, but Stain Magic should get it. If it doesn't come out right away, you can keep it wet to work best (cover it with saran wrap or plastic and tape the edges down to help it stay wet). Stain Magic stops working when it dries. Sunlight will help it too, if you can open the drapes/blinds in the room.
Goldenboy
Atkins
Mike Waldron
Stain Magic did not do jack. Used it first. Rinsed it. Red Vanish with a iron did it. It was a real biotch to get out.
Golden Boy
Goldenboy
Atkins
Mike Waldron
For a side note it was the kids V-8 stuff. Might be different then the crap my grandma use to put in her beer.
Golden Boy
