Promaster Fuel Tap
Montana
Swani
@Nomad74 or anyone else using a Promaster. Do you use an inline fuel pump to fuel your Truckmount or are you just running a fuel line to the extra fuel tap? The reason I ask is because I was just had my Everest running without any power to my inline pump. It made me think there's a possibility that it may not be needed? But also wondering if it will lose its prime?
My 870 is fuel injected so it has a pump running continuous pressure all the time. the pump and it's fuel filter are bolted under the van on the frame rail.
Reactions: Living The Dream
