Op Machine and VCT
Rob Lyon
Northeast Pa
Rob Lyon
Anyone know if one will work for stripping vct???
I am probably going to trade one of mine for some other equipment.
Sure it will. It's just slower than a rotary, but it doesn't sling the stripper on the wall like a rotary. So, it has it's advantages and disadvantages.
I use mine for stripping most times.
Dolly
I use mine all the time.........and it does not slig the stripper all ovr tha place.
I wish though it did not sound so much like a tractor........... :?
Clark
I have all the stripping brushes for VCT. Strata Grit, Strata Grit II, and Nylo Grit with the mounting cup already in it for the OP driver. The stripper stays under the brush and doesn't spin out. The stripper does the work. The brush keeps it moving.
leesenter
You need the things Clark is talking about because my OPs sling slurry all over the walls. Never use it for VCT again.
Jeremy
Indiana
Jeremy
I have a rotary & it will sling a bit... The OP with pads will sling a ton. I can't comment about the brushes as I do not have them...
Rob Lyon
Northeast Pa
Rob Lyon
I have the tile brush, is that what you guys are speaking about ??
It is a 15" conqueror that I picked up from John G about 2.5 years ago
and it is still in new condition. I am doing a trade for some water damage equipment as I do not use it that much.
All The Best, Rob
