Old style gekko wand
I have an old style gekko. The one where the spray bar obstructs the vacuum. Been sitting around the shop and decided I should put it into useable shape at least as a back up. One of the worst parts of this design is that the jets are very difficult to remove. There is not a lot of clearance between the jets and the inside of the wand. A regular long socket won't fit. Does anyone make an extremely thin wall socket or t-wrench that will fit?
Reactions: Desk Jockey
Poorly designed tool. Sad it is probably the one most people have. Mike's gilded brush could been the deal even if it works half as good as he claims it does. šŸ˜‰
Even their new design is sadly lacking. They are too cheap to even put a filter on the valve. Essential when you're using 11001 jets.
