Lead mitigation
Papa John
Lifetime Supportive Member
San Francisco, CA.
John Stewart
A customer stated that during a home inspection the inspector discovered they were tracking in lead onto their rugs and recommended in plant cleaning of the rugs.
I'm skeptical, But we'll take precautions and probably test the dust for lead myself.
What are your thoughts on this? Shouldn't she also need to have the surrounding area around her home cleaned as well?
Numero Uno
Ma
Caesar
Sounds like Scooter is getting a kick back from the inplant... How did he test the fibers ...lol. Drop that job...asap.
Unless you are willing to have the rugs tested for lead after cleaning, I wouldn't touch that job. Sounds like a law suit waiting.
Like Ron said. I would have it tested before it was reintroduced to the home. For all you know there is a constant rain of lead ceiling paint contaminating it although tracking lead in is apparently a thing (industry, exterior paint, etc)
I mean I guess I knew it was possible just figured most cases where it would be an issue were from interior paint and other things. Probably a customer I would avoid but you are used to dealing with the more special among us.
I'm a licensed lead abatement contractor, John.
I know a little
I'd like to see the lead risk assessment report.
There should be one if the "inspector" was a lead risk assessor licensed with the state* .
(*though Ca may be different than Ohio)
Highly unusual to have lead dust on rugs and not the floors too.
and the way every lead risk assessment report I've seen (two/three a month) if one surface (floor, window sill or trough) tests hot, all the rest are "presumed" hot
the report will also have the "recommended action"
for lead dust only, the recommended action is HUD cycle clean
(hepa vac/wet clean/hepa vac again)
To CYA ('cause you don't know the source nor if the rugs were removed to storage and house HUD cycle cleaned and passed assessor's clearance)
I'm with Ron
Whoever is licensed in your state to do lead clearance, you need to include in your cost the cost of the assessor's "pass" clearance report
(it's anywhere from $300 to $500 here)
Papa John
San Francisco, CA.
John Stewart
I had my son save the vacuumed dust and I'll plan on testing it. guess I should test the cleaned rug as well.
