Is this industry missing some....
Tool, gadget, machine or chemistry that make your/our job easier?
and would be something that appeals to 1000s of others and not just 3 weird Canadians...
steve_64
A training program for employees that will produce efficient consientous quality workers.
steve_64
It looks better in person.
Reactions: Dolly Llama
Hack Attack
further south than you
Dan
they put proper handles on vacuums that get used 10-20 mins each job, but still use the wand tube as a "handle" for the tool that gets used the most.. and the so called ergonomic are a bad afterthought and everyone using a 1.5" is proof of the problem (and no a 1.5 is not the solution)
  • Eyeroll
Reactions: Trip Moses
Lyman
Johnstown new york
Lyman
A 2 inch tube wand, 12 or maybe 13 inch wide, 4 or 6 jets, plastic or titanium, slot glide(f-ing popcorn under couches), that doesn't lock down or at 55 you can push it all day with ease. And be able to suck the dimbles off a golf ball. And not cost a fortune.
I would like to see a wand that is designed to clean stairs while working down the stairs in situations where you need to work against your hose, like working down into a basement.
Reactions: Old Coastie
Meter Maid
The Undetective
Dayton,Ohio
An edge tool for killing filtration lines (we get them here a lot) that you can use standing up, like a wand.
Maybe it's already around... if that's the case... link please.
I have one. It does the trick
Here ya go.
Reactions: Meter Maid
Bc
The filtration edge tool is outstanding
Don’t know whether you are serious or not Marty.
I use one when I do a greasy burger joint.
My helper vacs, I prespray, agitate with a CRB, but find it doesn’t go to the edge. I then use my edging tool @ 700 psi, with the heat cranked....
It works like a charm...
Reactions: hogjowl and Nomad74
Bc
Mine is different though... it was bought from Interlink supply, and is called the gum blaster.
It’s basically a 3” upholstery tool, with a full size 1.5 wand.... the valve is 1000 psi.....
