Apr 1, 2010 #1 Mikey P Administrator Joined Oct 6, 2006 Messages 116,050 Location The High Chapperal I did.. take that damn thing apart this weekend and lube her up.
Apr 1, 2010 #2 A amazingcleansc Guest Mikey P said: I did.. take that damn thing apart this weekend and lube her up. Click to expand... did you put a grease fitting on yours?
Apr 2, 2010 #3 Mikey P Administrator Joined Oct 6, 2006 Messages 116,050 Location The High Chapperal you bet
Jun 13, 2010 #4 ronbeatty Member Joined Nov 16, 2006 Messages 1,437 Location Altoona,PA Name Ron Beatty How do you install a grease fitting in the diverter, and what kind of grease do you use ?
Jun 13, 2010 #5 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin the old ones have a oil cup that you just take off and replace with a grease zerk........ the new one will probably need drilled and tapped..... the highest temp grease you can find will work just fine...........
