Harper's POS softener.
Harper unloaded this relic on me with out a manual.
The manual off the Hydroforce site is for a newer version that does not rely on electricity to operate the clock.
Anyone have one that can copy/fax/email the manual?
I'm pretty sure that model wasn't intended for Van mounting....and Automatic regneration doesn't do much good if it's 110v powered.
Good thing the Shoehorn won't see full time action, re-charging once a week would suck.
I think that was an old Hydroforce Softener, you plugged it in at night to regenerate.
Check with Shawn or Jim, I'm sure they have sold some of those units.
joe harper
florida
joe harper
:shock: HERE IT IS ON MY 405...DOuChbAg..............
"Use the LEFT-HANDED sCrEwDRiVer...." :roll:
Make sure you tell them what pAiD for IT.. :oops:
The BLUE JUG is the bRine Tank....... :?
joe harper
florida
joe harper
Richard,
That is a 1992 .....405 ....with 5700 hrs on HER.....The best machine I have ever OWNED..
It is my BACK-UP unit.....It is the only VAN we have left....ALL BOX TRUCKS NOW...
The Water softner has not been used in 2 years....."he got it PRETTY cHeAp..." 8)
No I meant the softener, Sorry i wasn't clear.
I like the Prochem's we had 6-like that at one time, we're down to 4 of them and the 805.
We have 3-in extended van's, 5-in box trucks.
joe harper
florida
joe harper
Richard,
Sofner came with the 405.....
Tell JUGHEAD...that he can google "PROCHEM WATER SOFNER" for a manual....
I believe it is called the ....EZ CHARGE...
joe harper
florida
joe harper
Richard here are some pics.....of the 405's.."LUCY"...new home...
This is the Truck the 805 was in........
So...tell about this thing. Did the plastic waste discharge line go over to the waste tank? Any issues with the daily salty brine in the Aluminum tank?
Did you always haul around the salt jug, or just set it in when you regenerated?
Did you do a quick 30 min, daily regen. or just plug it in once a month/week for 4 hours?
joe harper
florida
joe harper
Greenie,
I should have KNOWN...you would get SADDLED with this project.....
I just called your phone #....got recording....call me 352-588-2499...I'll give you the history.
I was going to say something about that, but Mexican's are known for rigging up their cars so I thought I'd leave it alone.
For the record I just put on a set of Cragar s/s and N-50's and air shocks on mine.
joe harper
florida
joe harper
Hey..........mAry...Where ya been ...?
You don't LiKe mY cArPeT..... :?: Green leaves....GREEN CLEAN. :wink: :wink:
It was overage from a CaSinO....from 10 years ago..... :oops: "$38.00 a sq yd.." :shock:
I have got some "PINK FLAMINGO" carpet from a Disney World job...WaNa do YoR bOx TrUCk.??
joe harper
florida
joe harper
Greenie,
Go to the INTERLINK SUPPLY website.....Type in ITEM # AC 40....
I think this is the same SOFNER.... :?:
PS the clear tube goes into the top of the BLUE "5 gal." brine tank...
Farenheit251
That control is made by Fleck. They make the controls for most of the softeners and all your local independent stores will sell and service. Look for a shop near a rural area where people use wells not a shop that specializes ripping people off by telling them the city water will kill them.
To recharge mine I run an extension cord to it,hook up water supply hose and unhook the QD to my fresh tank so not water is flowing,run a piece of tubing that is hooked to the softener and hook it to the brine tank in the garage that I use for my house unit,run the drain hose to my waste tank and manually advance the dial to get it started.
joe harper
florida
joe harper
Im sure you are joking about the CaRpEt....
And yes ....that is one of the Turbo-Dryers....I think it is a 3200...
Did you have any"LUCK" with the sofner...????
joe harper
florida
joe harper
I sold a TON of it..."SHAW CARPET"...Had the same pattern in my Carpet Store...
But it was the Purple & Blue color....Holds up great...Snow would LUV-IT....
I just run a hose from my house to fill up my machine.
Water softner in the house to the garage.
:shock:
