give me a list.............
give me a list of all the chemicals you have used on .....Tile ...UPH.. and carpet...and say if it was good or bad.....
example........
powermax - good
You're going to have to put out more effort than that to get me to go to all the trouble to list ALL the ones I've used.
JJ Juice - good (that's all you get currently)
vincent
O'Fallon, MO
Vincent Sapp
Carpet & Uph
PCA 5-----very good
Preface prespray---good
Releasit----excellent
Judsons----excellent
Tile
Oxyblaster-----excellent
PowerMax------Fair
Tile
Prochem Tile cleaner- 9.5
Viper venom- 9
Powermax- 8
Prespray
Powerburst- 10
Grease eraser- 9.5
Powermax cobb- 9.5
Judson juice with hot sauce- 9
Overrated powermaxx fibermaxx
Rinse-
Judson o2- 9.5
Dry slurry- 9
I've used
Zone perfect....good
ultrapac......good
trafficslam....good
flex......good
powermax.....good
judson o2......good
biobreak......not impressed but didn't give it a chance didn't try it on residential
grime reaper........ok
axiom.....wasn't impressed....haven't used much though
Powerstrike......good
Powerbreak.....good
Upholstery
I've tried the prochem stuff. Their woolsafe stuff....not too impressed with it
avenge HD.....good
I prefer to use judson o2 the most for upholstery
Rinse
dry slurry.....ok seems like a lot of filler
fabset.......fine for acid rinse
all fiber rinse (prochem).....fine for acid rinse
Endzone......good for acid rinse
point blue.....good
heat wave.....good so far....haven't made up my mind on it I think I like it better than point blue
shatter......so so....awfull smelling
O2 rinse.....good for neutral
White lightning......good for high PH of course
Scampoo
Releasit....good
Hot Knife....good
Tile.
TOG deep clean......good but strong smelling
Viper Renew........very good acid
TOG easy etch......good but I may go back to renew...seems to etch easier
Viper venom......good
Judson O2 w hot sauce....good
powermax.......good
Going to try....prochem all fiber deep clean, master blend soap free. There may be others that I've tried but can't remember. Any chem people want me to try their stuff, I'm willing to try it out. :wink: For the most part I've found most stuff works about the same and it comes down to RTU price and ease of cleaning. I prefer to be able to spray it on and rinse it out and that be it unless it's trashed. Of course I've tried a few spot cleaners too.....
Hey Jim
How about you compile a list off all the available juices and Powders and we can cut and paste it then add our comments.
Tia is away at her sisters anyways right?
I don't know them all but I bet I could put together a pretty good list............
I will see what i can come up with....
White Collar
Bentonville, Arkansas
Nick Petersen
Rinses
Point Blue- Didnt like it
Dry Slurry- Little better
02 - Good
Endzone- Good
PS
Powermax- Very good
Bio break- Different results, definatly needs a good boost
Ultrapac- Only tried it once and didnt like it
Judsons- Pretty good
AshleyMckendree
Versailles ky
Ashley Mckendree
It's hard to put things in a category of "Good" or "OK"
So I will put things on a scale of 1-10
Pre-Sprays
Grease Eraser - 9.0 = When mixed per directions.
Grease Eraser - 10.0 = When mixed 20% stronger - but insanely expensive
(Dynachem) - PowerMax - 9.5 (it gets .5 over GE just for smell)
(FiberMaxx) - PowerMaxx - 7.0 (It is a 10 on one job, then a 4 on a few others... like Im not using anything at all... I cant figure it out)
Judson O2 - 8.0 = w HotSauce @ 3oz/gallon (It gets an 11 on one job I do, that nothing else has even touched)
Matrix Grand Slam - 4.0 (Smells awful)
Formula 77 - 8.0
Detergents/Rinses
Judson o2 Rinse - 10.0
Butler Detergent - 7.0 (leaves tons of residue)
Matrix Finish first - 9.0 before they took out the STPP - 1.0 Now
High heat - 8.0
Heat Wave - 8.0
I am about out of my powdered Pre Spray.
I went through 3 buckets of MAXX and am now almost out of a (real) old bucket of Pre Klean.
I've tried MAX be fore but had real issues with getting it to run consistently though my HF.
I feel like I owe it to the groop here to see what all the hooplah is about.
maybe Larry will barter for a banner and if the X dont draw I'll clean grout with it.
sweendogg
Bloomington, IL 61704
David Sweeney
I liked the number rating system:
Presprays
Matrix Grand Slam 7.0
Matrix Grand Slam w/ CitrusForce ASD 9.0
Grease Eraser mixed per direction 9.5
Chemspec Traffic Lane Cleaner 3.5
Hydramaster Quake (pH of 12.8 to 13): 9.0
Judson's O2 6.5
Judson's O2 w/ hot sauce 8.5
Enzall 8.5
PowerBurst 8.5
Matrix New Decade 6.0
Matrix Olefin Prespray 7.5 (9.0 when its needed)
Planet Guard Prespray 8.0
Masterblend Fine Fabric 8.0
Rinse:
Formula 77 8.5
Matrix Finish First 8.0
Dry Slurry 8.0
New Decade Detergent 7.0
O2 rinse 8.0
Envirex Oxygen Release 8.5
Matrix Royal Mist 9.0
Matrix All Fiber Rinse 7.5
Chemspec All Fiber Rinse 7.5 smells like black licourice
Planet Guard Rinse 8.0
Super Encapsulation Plus Rinse 5.0
Shampoo + Encapsulators
Snap encap 7.0
Releaseit 9.0
Masterblend Oriental rug Shampoo 9.0
Double Strength Encapsulant 8.0
Matrix Champion Shampoo(13.0 pH) 7.5
Matrix Dynasty Oriental Rug Shampoo 8.0
Upholstery
Matrix Outset 8.0
Matrix Impression 8.0
Prochem for Cotton 8.5
O2 Juices 8.5
Chemspec Heavy duty soil lifter 7.5
Tile and Grout
Matrix Grout Devil 8.5
Stone Tech Stone and Tile Cleaner 7.0 (great mainenance)
Stone Tech Restore 8.5
Lots of spotters and deoderizers so here is just a list:
Matrix spotting Kit: Citrasolve Breakdown Release Target Rust Remover, Ink away, Oxidizer, Reducer, Red Cross, Spot Out and the other products:
Liqua Gel
Red Relief
Stain Magic
Power Gel
Kill Odor citrus
Urine Stain Remover
Urine Preconditioner
Bottom Line
Microban QGC and Space Spray Plus and natural fiber sanitizer
Master Blend Spotter, Magic, Fringe Bleach, Yellowing
Brown out
Citric Acid,
Red One
H2O2
Fels naptha
prochem filter out
vacaway line of spotters
wow...
Tim,Ash, and Sween's list remind me why I'm happy to stock the O2 system, just need more to try it on Grout and Uph. for more feedback.
AshleyMckendree
Versailles ky
Ashley Mckendree
Greenie said:
wow...
[attachment=0:3igafbec]QDOBA TILE.JPG[/attachment:3igafbec]
That is some NASTY urine soaked tile, Cleaned with Judson o2 3oz/gallon (No Hot sauce)
My camera really couldn't capture the pure NASTINESS of this tile.
Greenie said:
wow...
My list is of stuff I have tried.....I try to give everything a go to decide if I like it or not. I'm very open minded and have found that all the stuff works to some degree. However after trying all of those. I keep Powermax, and Judson O2 as my pre-sprays of choice. For price and quality of cleaning. But I really do feel that if the prespray is decent or average, I can clean just as well as a good prespray it just takes more work.
wired
Well it seems like most of you like Judson 02 and the rinse.Grease Eraser seems to be at the top of the list to. Tried Judson when it first came out worked great on white carpet really brightened it up. I did not have good luck on nasty carpets though. Had to break out the ultra pac.and sometimes alittle powerburst. Would like to try Judson again . Talked to jeff and he said they made some changes. Will call him and order some. Who makes Grease Eraser and what does it smell like. Can I get a sample?
Judson O2 by itself, or at least it's lowest dilution, isn't designed for filthy carpet. However you can increase the dilution and add their modifier to it. And it can clean about anything with some scrubbing and of course enough PS on the fibers to disolve the filth.
sweendogg
David Sweeney
Grease Eraser is Chemeister.. and I kinda of echo what Tim says.. I like to try things and keep and open mind about different products. Seems like everything has a time and place for the products. In the coming year I plan and trying some of the Cobb Powermax and will need to order more O2 system as I'm about out. But Its also nice to know that there are other products that work desent to very well and I can get them from our main distributer in a days notice.
Grease Eraser is a Chemeister product. You will have to take it up with your distributer for the free sample.
ascrubabove
Holly Ridge, NC
Prespray
Grand Slam good
Ultra TLC good
(both are better with a citrus boost like Hy-Speed Orange Burst)
Rinse
Last Step good (cut my wicking issues in half, and makes the colors pop out like new)
