CRASH WANTS ME TO
build him another Genie.....
and i jus happen to have one mount bracket left...
(circa around '84-'95
anyone know wheres there a church bus
you can run a 47 blower Direct Drive for $11,000 to 12 large...truck included!
perfect way to start...if i gotta rivet quarters on it'll cost him moer
i wuz keepin it a secret...... maybe...
prolly not!!
Reactions: SamIam and rwcarpet
Ann Arbor
Steve Lawrence
I hurt my back a week ago. Been kinda lame since. Good thing I'm off the truck. Can still do lame stuff for this biz. Changed oil in a van this AM. My git up and go got up and left, too.
I’m in the same condition. I did one MBR this morning 310 sf . Took me an hour and a half and I’m whipped! Of course, we ARE under in a heat advisory. 110 heat index, but still ... I shouldn’t be whipped after one room.
It’s the cardiac meds I’m on. Has to be.
Reactions: Lee Stockwell
Marty...you DO carry yor nitro pills every where you go...right?
I been carrying them for 15 years now....only had to use one time so far.....
But they did save my life......
steve_64
My brother had to have his lungs drained a couple times after his surgery. It gave him his wind back.
steve_64
prolly not!!
I didn't think he had enough work for 2 vans.
I'm takin Plavex.....or some generic form
Are yor stents teflon?
Tell yor doc to pull the damned bone outta his nose and prescribe you some nitro pills......in 15 years they saved my life once........isn't that worth carrying a little bottle in your pocket.....
How bout 81s....
One a day?
one small little nitro pill will force enough oxygen into yor heart muscles and brain to keep you alive for an extra 3 ot 4 min......
but you get a ma dicker of a hEDache...which i suppose is better than the morgue.....
has the wax plug next to yor ball sac fallen out yet?
Brian H
Detroit Michigan area
Brian H
I'm going post/pier for mine. 44'x18', 6/12 roof.
This is more of a standard build garage, though the layout is a bit unconventional. I had it designed to fit the setbacks mandated by the township. 25 feet off the road, 5 feet off the property line and 10 feet from the current attached garage. To the inch, it fits exactly into those dimensions.
Rob Grady
Sauble Beach, Ontario
Rob Grady
Heydere Bawb. I bought a Genie a year or so ago, I am pretty sure it will need a drive-shaft. Any idea where I could get one? It is in a 2006 gmc with a 4.8L engine.20161215_135930.jpg
Heydere Bawb. I bought a Genie a year or so ago, I am pretty sure it will need a drive-shaft. Any idea where I could get one? It is in a 2006 gmc with a 4.8L engine.View attachment 93191
They came in two lengths....I may have a 72" laying around somewhere ....any good machine shop can turn those welds off yours or even turn a new shaft for ya.....
Cut those welds carefully...then use those other two holes to push that pulley shieve off....
A set of Jap bearings and yor good ta go.....don use Chinese bearings
If it were mine I would get a new inner shaft turned while I had one apart.....they're like gold to anyone that really needs one
