Commercial ?
L
Larry B
On Commercial glue down that has tons of oils, dirt & food on it what would work better?
Floor machine with Brush or Bonnet?
I have a couple gallons of Release & Citrus Boost I was going to use on it. Do you think that will loosen the oils and dirt if scrubbed before extraction?
Use something stronger?
Carpet is green and all walkways in the place are now black.
Scott S.
Scott
i use the light tan pads. Jim pemberton turned me to them, and wow. just enough to really get the dirt loosed but not enough to damage the fibers.
C
Curtis Pennington
If its nasty,pre spray grease eraser with a little PIG, pre scrub with brush,HWE at 700 psi and post pad.
Jeremy
Jeremy
The citrus is probably resoiling. :roll:
L
Larry B
Done the job today! Used red pad with the 175 (first time on commercial) and it worked perfect.
The little china man was dooing flips when we were done and booked us for once a month cleaning of traffic areas and every 3 for the complete building.
I did leave out the citrus stuff and only used the release (was paid for). I dont know why I never used the 175 on commercial before.
