Commercial Carpet Protector and Encapsulation
Montana
Swani
Some of our commercial accounts I like to rotate quarterly between HWE and Encapsulation. I would like to sell more protectant but will something like Saiger's Super Sealer or Maxim F'Up the encapsulation process? Forgive me if I've already asked this or it's been covered.
Tom Forsythe
You do not want to apply a protector that causes re-soiling. Most solvent-based protectors, like our own, will promote re-soiling. Every water-based fluoro-chemical protector that I have tested, resists soil more than the polymers left after an encapsulation cleaning.
The key phrase is NONE OF THE SCAMPOO "RESIDUE" IS EVER VACUUMED OUT.
Montana
Swani
To be clear, you’re applying the protector after the HWE cycle?
If so, you’re good.
Yes, that's correct after HWE. I was concerned that the next quarter when I encapsulate it could in some way cause the carpets to be sticky or in some way have an adverse affect on the carpets when applying encapsulant.
Montana
Swani
Last time for one or our buildings I HWE'd and applied Advanced Protector with Teflon. Would there be any issue with encapping that 3 months from application?
Tom Forsythe
No issues with encapsulation and fluoro-chemicals after time duration. It is better to apply protector after extraction and encapsulate in between extractions.
Reactions: Living The Dream
Trip Moses
IMOL
Savannah GA
Trip Moses
I do. But I am a little taken back by the “re soiling promotion” talk. And the “ nothing ever really gets vacuumed out”.
everything Jimmy says is gold
whatever he posts, I carefully write on a post it note and place on my walls
Read enough of Jimmy's stuff, and this is how you will be writing on the walls.
encapman
St Petersburg, FL
Rick Gelinas
Trip Moses
IMOL
Savannah GA
Trip Moses
Soileze Protector: Designed to work in tandem with encapsulation. Complements the encap process. It’s exactly what you’re asking for.
The name Soileze sounds like a dietary additive to aid in the removal of skid marks. No doubts that it’s a great product.
encapman
St Petersburg, FL
Rick Gelinas
Soileze is fully compatible with Releasit encapsulation products. In fact, it's included in the formula of our primary encap detergents. Apply Soileze sparingly, a little goes a long way. Apply lightly at a rate of 400-600 square feet per gallon (applied undiluted). Use a spray tip that will deliver a fine spray pattern.
Montana
Swani
I just ordered your sample packs. I look forward to trying out your products.
encapman
St Petersburg, FL
Rick Gelinas
No worries... they're starting out from the Sunshine State.
And we got everything good-n-warm for you before the journey. :icon_razz:
In fact, Releasit products are freeze/thaw stable through 2 full cycles. So you'll be OK.
Thanks for giving the samples a try. Let me know what you think.
