Apr 15, 2020 #1 Steve D Member Joined Mar 1, 2019 Messages 61 Location Chicago Name Steve D'Aquila My chemical prime valve is leaking. There used to be a way to repack the valve with some type of cord as a maintenance routine. Does anyone know what I am talking about? Thanks
Apr 15, 2020 #2 G Glynn Member Joined Nov 26, 2006 Messages 231 Usually you can, remove the knob then slightly tighten the flats behind it.
Apr 15, 2020 #3 Mikey P Administrator Joined Oct 6, 2006 Messages 116,241 Location The High Chapperal Did you try just tightening the packing nut ? often that's all it takes
Apr 15, 2020 #4 hogjowl Idiot™ Joined Oct 7, 2006 Messages 49,519 Location Prattville, Alabama How often? Reactions: Hack Attack
Apr 15, 2020 #5 Mikey P Administrator Joined Oct 6, 2006 Messages 116,241 Location The High Chapperal as needed
Apr 15, 2020 #6 Steve D Member Joined Mar 1, 2019 Messages 61 Location Chicago Name Steve D'Aquila Glynn said: Usually you can, remove the knob then slightly tighten the flats behind it. Click to expand... thanks I will try that Glynn.
