Chem jug overflows
Jim Morrison
Canada
jim
Cleaning with my Cleanco yesterday and the chem jug started to overflow. The chem draw tube was back feeding. :?
Has anyone experienced this? Seems to me I read about it once but could not find anything by searching.
Bill Soukoreff said:
Hey Jim, clean or replace the checkvalve/filter on the end of the siphon tube.
Thanks for the referrals.
for easier reference...it is called a footvalve...and yes they can be cleaned out...don lose the little spring!
RThode
Alberta
Rick Thode
Jim:
You may also want to check a check valve that many units put at the pump end of the supply tube.
Rick
GeneMiller
Boca Raton
gene miller
back feeding is usually caused by a hole in the diaphragm assuming you have a chem pump on the pump.
gene
Jim Morrison
Canada
jim
I think the footvalve is shot, looks like the screen on the bottom of it is out of place, I could see the spring in behind it.
