carpet in a TM
is the purpose of carpet in a TM for noise deadening ? Seems to me that eventually one would have to clean it and if its on the floors,walls and ceiling, it'll be a wee bit of a bugger
packfancjh
Chris Hagen
carpet
I have a cust that says it's for insulation for the winter time. Has carpet on walls and ceiling.
B
Bob Foster
Good on the walls but I wouldn't put it on the ceiling. If you saw David's Aerotec at Connections it looked real sharp and finished.
guess it would also depend on what TM was operating, whether a slide in or PTO, whether gas, diesel or propane.
I know the carpet "looks" sharp, but what about function. As much as I like a TM to look clean and "pretty", if its going to be a PITA down the road, why bother. Its like those hotrods, all chromed up, but not meant for day to day use, unless they take 2-3 hours cleaning everything. :shock:
A
alazo1
For soundproofing on walls I could see it working. I used carpet to soundproof a bedroom and it worked great. To be fair the the carpet was on a makeshift wall made out of 2x3's about 3" from the actual walls. Basically creating a wall with an airspace so I don't know how much sound deadening the air space provided.
I wouldn't put it on the floor due to that I hose it down weekly.
Albert
