Best portable?
jrizo1
Wha is the best portable On the market?
One that can do carpet,tile and grout
Nobody on this board will admit to knowing anything about portables.
The porty you have is a good one... Imho, I'd add a inline booster so your carpet cleaning will get dry faster... The 2 2stage with the 1,200 psi pump is good for tile... You already have it, might as well work with what ya got...
There is no portable to br defined as best...your needs define the portable...analyze your needs, market, customers, etc...and see te best machine for you.
jrizo1
What is an inline booster?
Mytee and Nordic1 sells inline boosters... It's basically adding an additional vacuum to your current setup... It is one more cord, but still cheaper than purchasing a new porty...
http://www.nordic1.com/vac-boosters.htm
http://www.mytee.com/products/7303-air- ... Adm5JFLNT5
jrizo1
I have a:
OLYMPUS 1200PSI PORTABLE, HYBRID VAC
If I add a 7303 air hog mytee plus to it can I use a High speed RX -20.
