Antifreeze?
Willy P
Vancouver
Willy P
Is RV antifreeze safe to put in my little porty? I was used to heating my van and having heated storage but not now. I noticed the pump on my RV was a shurflo so is the winterizing antifreeze safe for my little guy? 200 PSI pump.
Should be fine. Flush out any water first, then recirculate it back to your fresh tank. Leave your bleed hose connected and on the tank as RV antifreeze can freeze in extreme low temperatures. Having an open ended hose connected will let the pressure out.
Willy P
Vancouver
Willy P
Thanks! I just bought that pump from George at TMS. It seems to work great.
Willy P
Vancouver
Willy P
Rv antifreeze ate the metal in the water box float in my thermalwave
I suggest windshield washer fluid
I'm taking my RV in to winterize it on Wednesday. I see they use a shuflo pump for water in the motorhome to pressurize the system.
AlienAgent
Ohio
Joe Gingerich
Straight out of the Sandia manual.
