2002 Vortex lower heat exchanger needed
cpoole
This isn't something thats laying around the shop but I figure it can't hurt to ask. My unit has a small crack in it but I can't seem to find out which tube it is so I need to order one. Thought I would check to see if someone has a repaired one or new. Once I get the new one install I'm going to open up the crack one to see if I can reapir it but I don't have time right now. Thanks
dealtimeman
Everyday is Saturday.
Fort Worth , Texas
Michael
you should call john at johns custom machine and he will want you to ship him your cracked on and he will zerox it and send you a new one.
cpoole
Thanks guys I called John and Areo Tech. They were both very helpful. Areo Tech has one in stock.
cpoole
Guys thanks again for all your help with the great info. I cut the back end off where the 90 goes to the divertor and threw it in the lake, found a small crack by the rod at the top so I wieded it up and no more leaks so far. I have some pics but it says ( sorry, the board attachment quota has been reached. )
dealtimeman
Fort Worth , Texas
Michael
so did you end up ordering a new one? or you just going to hope that one doesnt leak?
if you did order a new one what did it set you back?
cpoole
No thankfully I didn't order a new one but they were $1,100 plus frieght. The unit was made in 2007 so it was just replaced before I bought the truck. Its not the tube so it will last a while.
Once I figure out how to add pics I will share them.
