10 inch CRB from Clean Pro Supply
carpetjim
I of course want the Brush Pro 10, my research over the years has shown this is the best machine. I could go bigger but don't want to. Clean Pro supply has a 10 CRB, its Austrian built, and looks close to the brush pro. Cost is $1995. Can anybody tell me anything about this CRB please? I have not dealt with Clean Pro Supply, are they a good business to deal with?
Donwand
east coast
Brian
I own 2 of them. I wouldn't want one that was any larger or heavier. I use it on most jobs and it works great at digging out all the crud that's in the carpet and pulls the nap back up even on the most worn-out carpets. It's very important to remove the brushes and clean the crb each day. You definitely need a big heavy extension cord and need to secure the cord that comes with it from falling apart after using it over and over again. I believe I bought mine from Eric at zipperwand.com
carpetjim
Thanks
this is good information. Thanks.
The zipper wand is a little different, not much.
I left messages for clean pro supply with no real response, I guess zipperwand is the way to go.
Cheers
I have a better deal, and just so happen to be staying at Reg Rogers house next week, as we've been great pals for a long time, so if something we're to need attention down the road, it would be dealt with in lightning like fashion
carpetjim
Thanks for information. I am getting from your site that there is a 3 month wait? Do you think that’s standard for anywhere I order machine?
Thanks for letting me know availability. Could you please tell me how long the offer for glide and 10 inch crb will be. I am trying to budget this in in the next month or sooner if I have too.
Thanks
I'm not sure on how long I'll continue with that offer.
I'm actually hanging out with Reg at CCA today in Spartanburg, who's telling me they are out of stock of 10's for three weeks-ish...
carpetjim
Hi, I got my CRB 2 months ago, should have had it years ago. I clean it after every use. I use a comb to get hair out cause spraying does not do it fully. Any other ideas to get the hair out?
vacuum the carpet first to prevent the hair problem
Bc
Yup, go get a mechanics (Autozone,or equivalent), pick set. Still tedious, but works VERY WELL @ getting the crud out ….
Bryce C
DFW
Connecticut
Bryce
I get little fuzz balls all over the carpet sometimes when I use my crb. Is that normal? It is pretty annoying. I clean the crb out, but it seems like it just pulls that much stray fuzz from some carpets. I always vacuum first. I end up walking around and picking up little fuzzballs because they clog the glide on my wand. It's enough to make me want a big truckmount and a slot glide to suck those things up with ease.
That’s normal. Just run the crb over heavy soiled and heavy trafficked areas.
Reactions: Bryce C
