Zipper VS zipper SS
Brycey Boy, are you a pre-vac and clean type, a crb and clean, or a straight clean type of cleaner? I ask because the Zipper SS is more maintenance over the regular.. Hair gets wrapped around the spinners and if not taken care of can mess up the bearing.. I do reach for the 15" SS on commercial jobs over my 13" Zipper.. The 2" plays a big part.. Even if it's not heavily soiled, 15" makes quicker work of it.. As for residential, you could use it but it's more for commercial..
You can use anything anywhere, but is it the right tool for the task is more the question.....? It's doable and I've done it, but prefer the 360i/xl or crb and wand for residential.. It's a different movement and you'll learn to go into a room and clean the entry first, before sectioning off or squaring the room off..
Hope that helps!
  • Love
Reactions: SamIam and Bryce C
Bryce C
DFW
Bryce
Hope that helps!
I'm a prevac, crb (or 175/fiber pad for commercial), and then clean type of cleaner.
I only focused on being able to knock out commercial more quickly and with better results. The possible use of a Zipper on empty residential was an afterthought, not important. Does the Zipper SS really make a big difference in results when cleaning trashed greasy restaurant carpet?
Super spinner is pushing usually 1000 psi.
So pressure washing carpet.
That's why you need a big blower to use it.
That and hot water to keep up with the flow.
A lot of success comes from chemistry, you can't clean a greasy spoon with out a higher ph enzyme/citrus /butyl combo.
Something has to suspend and break the soil free, the SS will speed up the rinsing.
I personally wouldn't try any type of spinner on a cut pile carpet or residential piled carpet.
I would be afraid of crop circles.
If your doing a boatload of commercial jobs in restaurants then yeah the SS is probably what you want.
If you have one restaurant a month maybe not.
  • Love
Reactions: Bryce C
Excellent summery ..
Can your CDS maintain 200 degree plus at 1000 psi is the first question that need to be answered with a YES
Keep in mind Erik designed the SS to work with his AEROTECH
Siager's Butler is super hot as well.
Bryce C
DFW
Bryce
My CDS maintains a constant 220 degrees once it is warmed up. I upgraded to a fatty Blue Baron hx. And I can run 1000 psi no problem. But Erik says 800 psi is fine, no exaggerating...
Bryce C
DFW
Bryce
And I have a 4007 Tuthill blower. I am not currently doing that much commercial. But when I move to a new area and rent a commercial space I will need a good amount of work asap. Greasy spoon resaurants will help me establish my business. I may drop em after a year or so once I get re-established with residential. Or get a second tm and run a night shift guy.
Either way, I need to crush some disgusting cgd, and if all goes well I'll be doing a few per week....
Bryce C
DFW
Bryce
Hope that helps!
Whatcha got a 13' Zipper for, did you get that for residential?
I had to buy it second-hand when Erik wasn't selling to the general public.. Cintas bought the exclusive rights at the time.. I bought it for commercial cleaning.. I've used it on everything, commercial, residential, water damage, extracting pit-washed rugs, I'm the type to buy it, use it and comment back firsthand on pro's and cons.. Not like some of these armchair quarterbacks..
If you decide to use it for commercial purposes, you can always start with hot water from their tap, and it'll maintain heat better and longer..
I've run the SS as low as 600psi, and most were 1,200psi..
700psi is perfect if it isn't heavily soiled
800psi standard
1,000-1,200psi if heavily
Regular Zipper about 400-600psi.
I do believe Erik says the SS actually puts out less water than the regular........But don't quote me on that!
  • Love
Reactions: Bryce C
You know opinions are like assholes and elbows, everybody's got one. A regular Zipper is a good
tool Bryce on commercial. The advantage over a 360 or RX20 is no cord. On the other hand, reverse
the situation, if you can manage the
electrical outlets and the cord, the other is better.
Reactions: Bryce C
